Old 05-12-2006, 06:07 AM   #1
kkiepvvessau
kkiepvvessau is on a distinguished road
Default 1jz Gte 2.5l Twin turbo
jdm 1jz Gte 2.5l Twin turbo anyone know the Spec. Hp and Torque ?
swap in 93-95 SUPRA anyone know ..... ?
95 Supra SE
kkiepvvessau is offline   Reply With Quote
Old 05-12-2006, 12:25 PM   #2
pwpanas
Supra Owner
pwpanas's Avatar
As you may know, this engine never came from Toyota in the jza80 (Mkiv Supra chassis). As a result, you're likely to encounter differences in the motor mounts and the oil pan (at the very least). Worst case you'll also have problems associated with putting an engine from a RHD car in a LHD, such as interference between the intake manifold and steering column.
In addition the 1jz-gte turbos are parallel (not sequential like the 2jz-gte), so you'll have to run them in your Mkiv as you would a single turbo.
You'll also run into all of the standard n/a->turbo conversion issues such as fueling, ignition, etc. Which ecu were you planning to use with the swap?
I don't know hp&tq for the 1jz-gte offhand but I'd guess 320*(2.5/3)=266.7hp at oem boost levels.
Imho this is a questionable idea at best, but if you do decide to proceed please take notes and lots of pics to post here!
Life begins at 30psi.
Old 05-16-2006, 04:43 AM   #3
kkiepvvessau
i just find out today that , the engine basic exactly the same .my friend drop ir in his SC300 , IT sound weak maybe because it an automatic . ebay people listing is 280 HP 2.5l TT , and what get me confused is that 2jz GTE from the Soaror 280 Hp automatic .
95 Supra SE
Old 05-17-2006, 04:34 AM   #4
pwpanas
Supra Owner
pwpanas's Avatar
Since the engine is turbocharged, horsepower depends on boost level. You could probably call a 1jz-gte a 350hp 2.5l tt and still be accurate, technically speaking.
Since the displacement is about 17% less than a 2jz-gte, you can expect about 17% less horsepower at the same boost level.
Old 05-19-2006, 11:39 AM   #5
suprra_girl
7M POWAH! ;)
suprra_girl's Avatar
jdm stuff
2jz 280hp
1jz 280hp
easy huh
Pics of my build.
Do a diagnostic first!
Buying tips for a early '90's Twin Turbo modelseasii Non-Generation Specific Questions 0 04-18-2007 03:58 PM
1g-gteu twin turbo to 2jz twin turbo engine swap landspeedxxx MKIII Supra 7 03-30-2006 07:09 PM
