Old 05-17-2006, 07:15 PM   #1
G-string
G-string's Avatar
G-string is on a distinguished road
Default blow off valve
What does a blow off valve do exactly?
And where is it located on the engine
to much pizza makes me feal sick
G-string is offline   Reply With Quote
Old 05-18-2006, 12:40 PM   #2
Originally Posted by G-string
What does a blow off valve do exactly?...
Protects the turbos by dumping boost when you shift (i.e. when you let go of the accelerator).
...And where is it located on the engine
On the Mkiv Supra TT it's located above the front turbo, near the rhs cam/valve cover.
Blow off valve / idle issue AlpWhitE46 MKIII Supra 9 10-10-2008 11:49 PM
need help with blow off valve birdman9119 Non-Generation Specific Questions 0 07-05-2008 05:44 AM
blow off valve adapter projekt6 Non-Generation Specific Questions 1 04-04-2006 11:25 AM
