Old 07-09-2006, 10:41 PM   #11
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by Dom
hi Phil just put hks bov on and its blowing out a little oil is this normal?
Well the oil coming from that area is not ideal, but it is relatively common and could be considered 'normal' of a sort. The oil is probably coming from your PCV system (and should be fixed by the catch-can you've installed). There's also a small chance it could be coming from leaky turbo seal(s)...
Why aren't you running a 'recirc' fitting?
i also put this cusco catch tank on have i got it conected right
I believe so, but if you could post another shot from a 'front' angle so we can better-see the hookup on the valve/cam cover I should be able to confirm it.
Life begins at 30psi.
Blow off valve / idle issue AlpWhitE46 MKIII Supra 9 10-10-2008 11:49 PM
need help with blow off valve birdman9119 Non-Generation Specific Questions 0 07-05-2008 05:44 AM
blow off valve adapter projekt6 Non-Generation Specific Questions 1 04-04-2006 11:25 AM
