Old 07-09-2006, 04:37 PM   #1
gspots942jz
gspots942jz is on a distinguished road
Default Maf
I have a 94 2jz and i bought a blow off valve for it. I see that it has to recirc or the car wont run right, unless i get an aftermarket maf. Where can i get an aftermarket maf and what do you suggest? Any help appreciated.
gspots942jz is offline   Reply With Quote
Old 07-09-2006, 10:46 PM   #2
An aftermarket maf won't fix the problem. The only thing that will is going to 'map' instead of 'maf'...or running a recirc fitting. Those are the only two options. If you want to go 'map', a couple options are the MAP ECU (sold by PowerHouse Racing in the US), or the GReddy eManage Ultimate. I believe the MAP ECU comes out of Australia, so in Mount Juliet, there may be a different distributor.
