-   MKIV Supra (http://www.toyota-supra.info/forums/mkiv-supra/)
-   -   Maf (http://www.toyota-supra.info/forums/mkiv-supra/5293-maf.html)
gspots942jz 07-09-2006 04:37 PM
Maf
I have a 94 2jz and i bought a blow off valve for it. I see that it has to recirc or the car wont run right, unless i get an aftermarket maf. Where can i get an aftermarket maf and what do you suggest? Any help appreciated.
pwpanas 07-09-2006 10:46 PM
An aftermarket maf won't fix the problem. The only thing that will is going to 'map' instead of 'maf'...or running a recirc fitting. Those are the only two options. If you want to go 'map', a couple options are the MAP ECU (sold by PowerHouse Racing in the US), or the GReddy eManage Ultimate. I believe the MAP ECU comes out of Australia, so in Mount Juliet, there may be a different distributor.
