Old 07-21-2006, 06:03 AM   #1
2JZEFINI-17
2JZEFINI-17 is on a distinguished road
Default Auto or 6 speed???
Ok in one month I am hoping to pick up a 93-98 supra, I really want the 6 speed but they are so expensive and rare that it is really giving me a headache.... I am however getting the TT for sure... I want to know If there is a huge difference in the 6 speed/auto if the supra is at BPU level. Is the auto faster or slower then the 6 speed? Alot of my buddies have been telling me the auto is faster... Is this true. Any help would be apreciated.
Thanks alot..
2JZEFINI-17 is offline   Reply With Quote
Old 07-21-2006, 06:07 AM   #2
tone loc
tone loc's Avatar
auto is faster in stright up level surface drag race because it gets rid of the human element and thats all i know about the big diffrences. sorry for the bad spelling
Old 07-21-2006, 09:40 PM   #3
2JZEFINI-17
How much horsepower can the automatic handle without being under any real stress? I know that the gatreg 6 speed can handle well over 1000...
Old 07-25-2006, 09:35 AM   #4
pwpanas
Supra Owner
pwpanas's Avatar
The auto can handle 500rwhp or so before it starts slipping. There are a few companies that offer to rebuild the internals, but that'll only get it up to about 650rwhp or so reliably (depending on exactly how hard you drive, the tires you're running, etc.). Most Mkiv owners that are 700rwhp+ with an auto swap to a TH400..
Life begins at 30psi.
Old 07-26-2006, 11:02 PM   #5
supramanocnsd
supramanocnsd is on a distinguished road
Well the 6speed can take alof of HP.. with the right clutch.... The auto is alittle lighter and spools much faster... he is right about the stock trans tho.. 500 hp and it's time for a better tq converter... and a rebuild if you wanan go faster.... But traction is the key with the auto.. you link up and go... the TH400 is by far the best upgrade you can make to an auto TT Supra... TT or Single.. the th400 is sweet... or the auto light... those auto's run 7's... but thats a $5,000 trans... I have a 94 auto TT Supra... I've drove alot.. of 6speeds and I'll tell you this.. traction is key in any event... ^speeds make big RWHP on the Dyno then slip and ruin clutchs on the strip... Auto's grab the track and run... and there is nothing like not haveing to shift gears while getting your girl to give you some road head with the targa top off.... But hey that's my opinion..... Buy what makes you happy.... Drive a few of each.... that's what I did...
supramanocnsd is offline   Reply With Quote
Old 07-28-2006, 12:23 PM   #6
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by supramanocnsd
...The auto is alittle lighter and spools much faster...
The transmission itself is lighter? ... or the rotating components of the driveline?
With the oem flywheel I agree that the rotating components of the 6spd are heavier, but very few mkiv owners that drag race run the oem flywheel. ...and if you're talking about the transmission itself, the auto is much heavier (I've carried both, so I'm speaking from personal experience).
Overall good post though ... as I posted earlier I very much agree with you that an auto is the way to go if you're serious about drag racing the mkiv...
Old 07-28-2006, 05:20 PM   #7
supramanocnsd
The rotating components of the driveline are...... if you wanna get tech on it a 6sp weighs 3415.. the ttauto 3425.. only 10lbs..
Old 07-31-2006, 11:06 AM   #8
pwpanas
Supra Owner
pwpanas's Avatar
If you wanna get tech, try picking them up yourself. The difference is a LOT more than 10lbs. Part of the explaination of the similar overall weights has to do with the heavy oem flywheel that stays on the engine when you remove the 6spd...
Old 08-04-2006, 12:44 PM   #9
JustinCT
JustinCT is on a distinguished road
The question is...what do you prefer...an auto or a manual? I prefer a manual so I just waited longer and saved more. Just make sure you get what you want the first time you buy. No sense in rushing into something that isn't exactly what you hoped for. It sounds like you'd prefer a 6 speed, so I recommend you just save a bit more and wait for the right car to come around.
JustinCT is offline   Reply With Quote
Old 08-07-2006, 08:38 PM   #10
supramanocnsd
That's physical.. not Tech.. and I have.... it's 10lbs... the flywheel is not the prob.... it is heavy.. but no the prob Why are we talking about this???
New to MK4 (Auto TT to 5-or 6 Speed TT?) Mattz32 MKIV Supra 2 11-01-2008 06:25 PM
Want to switch a auto n/a to a turbo 5 speed Joe90rs Non-Generation Specific Questions 0 05-13-2008 06:04 AM
5 speed harness on auto? go.stfu MKIII Supra 2 10-09-2007 01:57 AM
