Old 09-30-2006, 01:51 AM   #1
8Ball
8Ball is on a distinguished road
Question OD/off light
On my 93 twin t It has a auto tranny. It works good like it allways has. The OD/off light flashes. Has anyone ever heard of this problem? Any advice would be great. The dealership had it for a day and could not clear it. Thanks- Shawn. Note I can not pass an inspection because they see the flashing light.
8Ball is offline   Reply With Quote
Old 09-30-2006, 02:58 AM   #2
bpalmer21
bpalmer21 is on a distinguished road
I dont know what the problem is, but I would take the shift knob off and disable the switch. I got tired of hitting it on accident. Cant help with the code sorry.
1993.5 N/A Supra
bpalmer21 is offline   Reply With Quote
Old 10-01-2006, 06:04 AM   #3
apophis
apophis is on a distinguished road
the overdrive light flashing means that your ECU has just recorded an error code...
now that means 1 of 3 things...
1) ones of ur fluids is low (ie brake fluid)
2) one of ur sensors has reached the end of its lifespan
3) there is something seriously wrong with ur car...
my advise to you is to check your fluids,
and if thats ok, do a diagnostic check of ur car...
heres a good site that tells u how to do that (b4 you do that though, u might want to check if the japanese spec ECU is the same as the US one)
http://mkiv.supras.org.nz/techo.htm#ENGINE_CODES
anyway, if that doesnt show anything, u should try reseting ur ECU...
apophis is offline   Reply With Quote
Old 10-02-2006, 11:16 AM   #4
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by apophis
...heres a good site that tells u how to do that (b4 you do that though, u might want to check if the japanese spec ECU is the same as the US one)
Here's more on checking codes in the us-spec mkiv:
http://www.mkiv.com/techarticles/eng...bd1_codes.html
http://www.mkiv.com/techarticles/eng...bd2_codes.html
Life begins at 30psi.
Old 10-03-2006, 11:27 AM   #5
pwpanas
Supra Owner
pwpanas's Avatar
Is your 'trac' fuse still installed, or has it been removed?
Old 10-10-2006, 09:03 AM   #6
8Ball
It still is in place the guy that had the car before me had the TRAC system disabled. But not by pulling the fuse. I am still not sure what he did. No matter how the trac off button is the trac and tracoff light seems to have a mind of its own. My speed does cut out at 155mph or so as far as I can tell. 8Ball.
Old 10-10-2006, 11:41 AM   #7
pwpanas
Supra Owner
pwpanas's Avatar
Just a couple of suggestions: Check under your ecu cover and see if your trac ecu is still there. Also ensure your harness is plugged into both the trac motor and the secondary tps on the throttle body.
light on dash that tells you a light is out D_Train MKIII Supra 7 08-04-2007 05:10 PM
battery warning light / tail lamp failure warning light MattJ MKIII Supra 5 02-06-2006 07:22 PM
light issue kewlcoconut MKIII Supra 5 11-24-2005 04:28 AM
1998 Supra Check Engine Light SupraLady Non-Generation Specific Questions 2 12-15-2004 11:39 PM
