Old 12-06-2006, 04:32 PM   #1
URNVS
URNVS is on a distinguished road
Default 1995 factory alarm bypass?
Can anyone confirm that my car is indeed missing the factory security ECU? If so is there a way to bypass this module so that it will at least turn over?
Name:	Supra plugs.JPG
URNVS is offline   Reply With Quote
Old 12-07-2006, 05:25 PM   #2
Have you checked the wiring/electrical TSRM?
Old 12-08-2006, 01:10 AM   #3
URNVS
Yeah, I couldnt really conclude anything useful from the manuals since they assume the module is already there.
Old 12-11-2006, 08:00 PM   #4
The manual describes all of the signals in the harness, and it should provide enough info to bypass. Either way, have you tried purchasing another unit (used or new)? I'm sorry to say that personally I've never tried to run an mkiv supra turbo without this ecu installed, so I don't have any quick-fix remedies/workarounds for you...
Old 12-11-2006, 10:10 PM   #5
URNVS
Its +12v to pin 25 and Im looking for a used module (I dont see the point in buying a new one when one of the first things the car gets is an aftermarket alarm).
MKIV OEM Factory Stock Bypass Valve (BOV) Bullz_EyE MKIII Supra 0 01-23-2006 02:47 PM
Factory Alarm dcrusupra MKIII Supra 4 11-16-2005 03:07 AM
How to Disable Factory Alarm? Dejvid1785 MKIII Supra 6 10-17-2005 07:17 PM
