Old 03-04-2007, 01:18 AM   #1
hp1975
hp1975 is on a distinguished road
Default Cheap wheel/rim suggestions?
Hi,
I have a MKIV supra (1994 baltic blue turbo w/stock chrome wheels) that I use for daily commute. Recently, my right rear wheel got trashed, and even though I have new tires, the right rear tire still leaks 'cause the outside of the rim is messed up.
Can anyone recommends a set of new rims/wheels that are:
1. Cheap
2. Tough. Stand up to the daily commute.
3. Have recessed rims. I don't like the chrome stock ones 'cause the outside of the rims get easily scratched up, especially when I parallel park 'cause I suck at it.
4. Are stock size, 'cause I just got new tires (Kumho Ecsta ASX) and don't want to replace them.
Stock wheels sizes are:
Size PCD Offset(s) Centerbore Weight (lbs) Finishes
17X8 5X114.3 50
17X9.5 5X114.3 50
I don't really care how they how they look 'cause my supra's old (~160K miles). Can you send me the links to the web sites and wheel?
thanks a bunch!
Huang
hp1975 is offline   Reply With Quote
Old 03-04-2007, 04:31 PM   #2
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by hp1975
...I have a MKIV supra (1994 baltic blue turbo w/stock chrome wheels) that I use for daily commute. Recently, my right rear wheel got trashed, and even though I have new tires, the right rear tire still leaks 'cause the outside of the rim is messed up.
1. Cheap
17X8 5X114.3 50
17X9.5 5X114.3 50
I don't really care how they how they look 'cause my supra's old (~160K miles). Can you send me the links to the web sites and wheel?...
If you're looking for something cheap, nothing oem-sized will beat the price of a used oem rim...and they're tough too.
Note that most aftermarket rims are built for looks and are light-weight, the two factors that really aren't present in the stock rims.
Recessed rims are more a factor of the tire than a factor of the rim itself. If you put 245s or 255s on your front rims and 275s or 285s on your rear rims, the rubber sticks out beyond the rim lip. In addition, certain tires have a rubber ridge on the sidewall designed to protect the lip of the rim.
Are you looking for one rim to replace your right rear that's leaking, or a full set? If you're only looking for one, I'd strongly recommend against running anything other than an oem rim. Running mismatched rim weights is one way you can throw off the performance characteristics of your Supra, and could possibly lead to a dangerous imbalance...
To sum up, I'm pretty sure your best choice will be to look for used stock rims. For the most part, they meet all of your criteria (assuming you pick the correct tire). As you might have already seen, the vast majority of aftermarket rims are lightweight (designed for racing, not potholes) and relatively expensive, with an emphasis on looks. Here's a link to a place where you might find a used set of oem rims :
http://www.toyota-supra.info/forums/...splay.php?f=17
Life begins at 30psi.
Old 03-04-2007, 11:35 PM   #3
hp1975
Default cool!
awesome, thanks for the advice!
Old 03-14-2007, 10:12 PM   #4
WhisPer
WhisPer is on a distinguished road
also just to let you know almost all "cheap" rims such as rotas or whatever are all VERY weak I know from experience. If you do buy cheap rims watch out for potholes, rocks, curbs because they may bend easily.
also pwpanas has a great idea because if you take that route then you only need 1 rim not all 4.
WhisPer is offline   Reply With Quote
Cheap Suggestions for a 1989 Supra N/A 5spd? V1P3R MKIII Supra 7 03-07-2006 02:36 PM
