Hi, If you all don't mind, does anyone know if the TRAC is disable/pull fuse/remove , will that cause the abs stays on?
It's a 1997 TT auto. thanks in advance. |
#2 | |
![]() Quote:
Phil '94 Supra Turbo, 6spd, 'APU'+ Displacement is no replacement for boost. Life begins at 30psi. NB: Please consider posting any help requests in a new thread instead of asking me for help privately. About 99.9+% of the time, private help requests end up covering great information that could be very valuable to other forum members. If you have a good reason for needing the help request to be private, I'll consider it. If not, then why not give everyone else the opportunity to pitch in too, and/or learn from the information? Remember, there's no such thing as a dumb question. We're all here to help within this family of Supra owners. |
light on dash that tells you a light is out | D_Train | MKIII Supra | 7 | 08-04-2007 05:10 PM |
battery warning light / tail lamp failure warning light | MattJ | MKIII Supra | 5 | 02-06-2006 07:22 PM |
light issue | kewlcoconut | MKIII Supra | 5 | 11-24-2005 04:28 AM |
1998 Supra Check Engine Light | SupraLady | Non-Generation Specific Questions | 2 | 12-15-2004 11:39 PM |
