#2 | |
SP58GT
![]() Quote:
you need to tap into the ECU, all government restrictions are set in the ecu, some engine management programs allow you remove the speed limiter as well as the rev limiter, when you get it tuned or if you tune it yourself, the program you use, unless its piggyback can remove both limiters...the rev limiter can be reset, but watch out...too high and youll grenade the motor, the speed limiter...dont know why you would want to remove it unless youre gonna use it to race...otherwise...id call you stupid for going over 120 on public roads
Now: Saving for an MKIV Broken Rides: (Sold) 91 supra turbo 5speed with a 1jzgte motor 421whp 400(399) ft*lbs of torque on tap @ 15 psi "Always outnumbered, never outgunned." |
Blitz MSTT Speed adjustment | SunDan | MKIII Supra | 5 | 11-17-2009 07:41 AM |
speed sensor problem | nadircicek | Non-Generation Specific Questions | 8 | 10-09-2009 05:58 PM |
top speed limiter removal? | marmlr339 | MKIV FAQ | 7 | 05-25-2008 06:38 AM |
Speed limiter cut greddy defender | old dude | MKIII Supra | 5 | 04-08-2007 07:48 PM |
greddy speed limiter cut | FullOfProblemsMKIII | Non-Generation Specific Questions | 3 | 04-07-2006 03:28 PM |
