Old 04-12-2007, 05:31 PM   #1
randychunn
randychunn is on a distinguished road
Default need a ecu-map for my map-ecu
i would like to go to a with a dyno,but the problem im in mississippi and 300+ miles from any repitable specialist,could someone guide or send me a map if they have a simular set up,thanks in advance,i will hold noone responsible for any damage
Randy C.
my car is an auto
i have a map but it has a dead spot around 2k
sp63
stock cams
3 row fmic
4000 stall
4in custom exhaust
randychunn is offline   Reply With Quote
Old 04-13-2007, 01:33 PM   #2
pwpanas
Supra Owner
pwpanas's Avatar
Randy C.
my car is an auto
sp63
stock cams
3 row fmic
4000 stall
4in custom exhaust
Have you tried the PHR or MAP ECU (Australia) websites?
Did you purchase your MAP ECU brand-new? If so, the vendor you purchased it from should be able to supply you with a better map.
Lastly, do you have any way to determine your air-fuel ratio at that 2k dead spot (eg. Wideband O2/Data logging)?
Life begins at 30psi.
Old 04-16-2007, 04:27 PM   #3
randychunn
Default bought the car used
motor was bad when i bought the car,#6 piston was broke,i put in a new shortblock and went through the head,thats way im tring to get a map from some nice supra owner,i have a basemap from map-ecu,but im sure theres someone out there that can save me alot of time,i do have a innovate stand alone wideband,so i can keep an eye on the mixture
thanks
randy
