Old 05-22-2007, 05:14 AM   #1
jaebers
jaebers is on a distinguished road
Default ABS problem with 650 rwhp Supra
Hello. I have a 97 that received a turbo upgrade plus lots of other items this past winter to get it above 600 rwhp. However, I'm having a pesky ABS problem. Either ABS codes 11 or 13 come on when the brakes are applied and the ABS is not activated. However, when I check continuity on the applicable wires from the solenoid relays to the ABS ECU they are in spec and I can reset the codes by pumping the brakes 10 times in less than 5 seconds. However, as soon as I turn on the car, move a few feet and apply the brakes(without engaging the ABS) the code reappears.
The car has had a serious autocross life so I am replacing both relays. Also, I am beginning to wonder if the front of the ABS actuator/pump is getting too hot due to its vicinity of the turbo, which does not have a thermal blanket...yet (and is on order).
Any info is appreciated.
Thanx!
jaebers is offline   Reply With Quote
Old 05-22-2007, 11:27 PM   #2
pwpanas
Supra Owner
pwpanas's Avatar
This may be kind of a shot in the dark, but have you bled the braking system recently? Also, what does your TSRM say about those two codes?
Life begins at 30psi.
Old 05-23-2007, 01:36 PM   #3
jaebers
I haven't bled the brakes lately, but I can give that a try.
DTC 11: ABS Solenoid Relay Circuit: This relay gives power to each ABS Solenoid. After the ignition switch is turned on, if the initial check is ok, the relay goes on.
DTC 13: ABS Motor Relay Circuit: The ABS motor relay supplies power to the ABS pump motor. While the ABS is activated, the ECU switches the motor relay on and operates the ABS pump motor.
I can clear each of these codes with the ignition swich on, the diagnostics jumper in place and pumping the brakes. However, as soon as I turn on the car move a few feet and apply the brakes (without activating the ABS) one of the codes reappear.
Old 05-24-2007, 01:02 AM   #4
pwpanas
Supra Owner
pwpanas's Avatar
Both codes appear to be related to the abs control circuits. If you don't answering one obvious possibility: Is it at all possible that a harness connector has come unplugged, or is not plugged in securely?
Also, your TSRM should have a troubleshooting guide for these two DTC codes. They typically involve checking the voltages/resistances/continuities/etc of harness connections and sensors. Have you already gone these steps for both DTC 11 & DTC 13?
Old 05-24-2007, 02:15 PM   #5
jaebers
I have been using the TSRM exclusively to help troubleshoot these codes by checking the items you mentioned. I was checking things again last night and I may have found the problem (possible broken wire that occasionally loses continuity when racing, but not during testing---ugh). Since this issue is intermittent, it has been difficult to track.
Thanx for your input.
*_*_*_*HavInG ProBLem WitH 87 SUprA (NO SPARK) d_demaree Non-Generation Specific Questions 5 05-22-2006 07:29 PM
HELP!!!! '87 Supra idle problem Morpho MKIII Supra 0 10-03-2005 02:40 PM
tsp problem for na t supra jdlee123 MKIV Supra 0 09-02-2005 06:01 PM
overheating problem on 1990 supra turbo suprasux MKIII Supra 16 06-13-2005 10:39 PM
