Old 06-11-2007, 06:36 AM   #1
Slice
Slice is on a distinguished road
Default I have seen the light
I've decided to finally purchase a Supra(MK IV) and was wondering what I should do. I'll be buying a manual non-turbo and swapping in a GTE. The only big question I have is has any one used the head from an IS 300 to use the VVT in combination with a GTE bottom end and is it worth the cost. I will be searching for a 6 speed transmission as well and turning the car into a fun weekend ride when I feel the need for boost. Any ideas and thougts are welcome.
Slice is offline   Reply With Quote
Old 06-12-2007, 12:51 AM   #2
pwpanas
Supra Owner
pwpanas's Avatar
There's a lot more to the MKIV TT than just the gTe. See this thread, for a start:
http://www.toyota-supra.info/forums/...48&postcount=7
Life begins at 30psi.
light on dash that tells you a light is out D_Train MKIII Supra 7 08-04-2007 05:10 PM
battery warning light / tail lamp failure warning light MattJ MKIII Supra 5 02-06-2006 07:22 PM
light issue kewlcoconut MKIII Supra 5 11-24-2005 04:28 AM
1998 Supra Check Engine Light SupraLady Non-Generation Specific Questions 2 12-15-2004 11:39 PM
