Old 06-29-2007, 12:22 AM   #1
JPDsupra
JPDsupra is on a distinguished road
Question Optimal Size
What is the best size for a wheels on a supra mk4 not width size just diameter and what would be a good wheels and tires combo for it? The guy at the shop said I should stay as close as possible to stock because the car will ride better and I wont have any problem with retuning the speedometer.
I was thinking about getting these:
They are VR1's from http://www.forgeline.com/wheels/vr1.html and they come in 18x11 and 18x13 and a relatively light and a bit expensive
JPDsupra is offline   Reply With Quote
Old 06-30-2007, 12:39 PM   #2
pwpanas
Supra Owner
pwpanas's Avatar
Whoa. You know a 13" wide rim won't work unless you're running a widebody, or at least flares, right?
Fwiw, I generally agree with the advice you got the guy at that shop. If the offsets on those rims are correct, and you have flares or widebody, those rims are a good combo for the jza80 chassis.
Life begins at 30psi.
bolt size? west_side_supra MKIII Supra 5 04-08-2007 06:18 PM
Whats the best catylac converter size 88Tsupra MKIII Supra 6 02-09-2007 07:58 AM
Tire Size boogum7 MKIII Supra 1 01-19-2006 05:14 AM
