Old 08-22-2007, 03:46 PM   #1
cjcarbone
cjcarbone is on a distinguished road
Default 4th gen help
my friend just purchased a 98TT completely disassembled. It has a Titan motorsports engine, 74mm turbo, AEM plug and play, and many other mods. This car has been apart for over 4yrs, and i'm putting it back together. Does anyone have pics of the engine bay with the engine out preferably. The car was disassembled to the point that the brake booster clutch master and both wiring harnesses, as well as everything else, was removed to paint the engine bay, and i'd like a reference point to start. I have already installed the booster, both harnesses, abs unit, and the brake lines. i just want to make sure i'm doing good, It looks to me like im ready to drop the engine in.
cjcarbone is offline   Reply With Quote
Old 08-24-2007, 05:25 PM   #2
pwpanas
Supra Owner
pwpanas's Avatar
Do you have the TSRMs?
Life begins at 30psi.
Old 08-27-2007, 12:20 AM   #3
cjcarbone
what is TSRM's?
Old 08-27-2007, 12:22 AM   #4
cjcarbone
yes i do, but the engine bay is completely gutted for paint, i just wanted some pics to get an idea where stuff is located. the manual isnt very helpful; with pics of locations.
Old 08-28-2007, 01:19 AM   #5
pwpanas
Supra Owner
pwpanas's Avatar
http://www.mkiv.com/mkiv_gallery/mki...ine/index.html
Old 08-28-2007, 02:05 AM   #6
cjcarbone
Wow. thanks much!!!!
Old 08-28-2007, 02:15 AM   #7
pwpanas
Supra Owner
pwpanas's Avatar
You're very welcome. Personally though, I find the 'cutaway' and 'exploded' pics in the TSRMs (along with the torque spec for each and every bolt) much, much more helpful than an engine bay photo.
Old 08-28-2007, 02:36 AM   #8
cjcarbone
oh they are very helpful... jus finding the locations of the abs block and the cruise module and the such help to get me started, it wasnt such a big help... i am definately going to use the torque specs soon!
Old 08-28-2007, 04:56 AM   #9
pwpanas
Supra Owner
pwpanas's Avatar
I'm being 'as serious as a heart attack' when I tell you not to bother putting your Supra together if you don't use the torque specs. In other words, if you don't always use the torque specs, the very best you can hope for is that part(s) on your Supra absolutely will fail, 100% for sure ... and the worst that can happen is that those part(s) will fail while you're driving at a high rate of speed (leaving us with one less forum member). I'm absolutely not exaggerating the risk in the least little bit! (I know other experienced forum members will back me up on this). A 74mm turbo puts your Supra at 900rwhp+ ... of course, it'll never hold together if one were to GUESS at how tight to make each bolt. I hope I have misunderstood you, and that maybe you haven't started putting anything together yet.
Old 08-28-2007, 05:07 AM   #10
cjcarbone
oh no, you definately misunderstood me. I said i was getting the engine bay ready to install the engine, and that i will be using the torque specs soon, meaning i havent gotten to that point yet, i am a professional tech, i repair exotics,ferraris, lambos and porsches, i most definately torque EVERY bolt, down to the t-stat housing! Glad to see that people here actually care though!!!! Thanks!!!!
