I'm currently building a 98 Supra, with a Titan Motorsports engine, 74mm turbo, 4" exhaust, FMIC, full fuel system, AEM engine management. I'm looking to get a max of 800hp on high boost, but a more reasonable 650hp at a regular boost level, used mainly as a weekend driver. I'm looking for a clutch/flywheel combination, that:
A: does not have extremely harsh engagement characteristics, i.e,"chatter" "on/off switch" B: reasonable pedal feel C: ability to handle power reliably i.e, 25k miles or more of regular street use. D: reasonable pricing any help will be greatly appreciated!!! Last edited by cjcarbone; 08-27-2007 at 04:57 PM. Reason: added to it |
#2 | |
![]() Quote:
If you really do mean 800rwhp (and not 800hp), then there is no clutch that meets all of your criteria. If you don't mind me asking, what line of work (or study) are you in? On the other thread you said "...i am a professional tech, i repair exotics,ferraris, lambos and porches..." - I guess they don't tell you how to spell Porsche when they work have you work on them. ![]() ![]()
Phil '94 Supra Turbo, 6spd, 'APU'+ Displacement is no replacement for boost. Life begins at 30psi. NB: Please consider posting any help requests in a new thread instead of asking me for help privately. About 99.9+% of the time, private help requests end up covering great information that could be very valuable to other forum members. If you have a good reason for needing the help request to be private, I'll consider it. If not, then why not give everyone else the opportunity to pitch in too, and/or learn from the information? Remember, there's no such thing as a dumb question. We're all here to help within this family of Supra owners. Last edited by pwpanas; 08-29-2007 at 12:41 AM. |
#3 | |
![]() Quote:
#4 | ||
![]() Quote:
Either way, you can't have it all. If it holds 800rwhp and it's smooth, it won't be "reasonable priced". If it's reasonable priced and smooth, it won't hold 800rwhp. Etc. Sorry to break the bad news to you, sir. Just pick any two of the three and I can probably find a product for you. Quote:
Phil '94 Supra Turbo, 6spd, 'APU'+ Displacement is no replacement for boost. Life begins at 30psi. NB: Please consider posting any help requests in a new thread instead of asking me for help privately. About 99.9+% of the time, private help requests end up covering great information that could be very valuable to other forum members. If you have a good reason for needing the help request to be private, I'll consider it. If not, then why not give everyone else the opportunity to pitch in too, and/or learn from the information? Remember, there's no such thing as a dumb question. We're all here to help within this family of Supra owners. Last edited by pwpanas; 08-31-2007 at 01:56 AM. |
ok well smooth and holds 800Rwhp. by reasonable priced i mean, not 5grand! like, say 2500 is my budget for this clutch and flywheel. hopefully. if its more, oh well. appreciate all the help!!!that is if the stock dual mass wont handle the power!!!lol
#6 | |
![]() Quote:
For about $2500 you can get a clutch that holds 800rwhp just fine, but it has a stiff pedal pressure and when it grips it grips hard. These are race clutches!!!! They're designed to handle abuse, like repeatedly dropping the clutch at 6K to launch in the 1/4, with SLICKS! ...they're NOT designed to ensure your g'friend doesn't smear her makeup while driving to the opera. Your oem clutch will only hold about 400rwhp before it starts to slip...and if you drive aggressively, it won't hold 400rwhp for very long. So which one do you want to give up on, slick? 800rwhp? smooth? ...or reasonably-priced? Just pick one to give up on (or two to use), and then don't mention it again. If you can do that, then I can help, and you can take my advice to the bank. In other words, I don't BS...I have my own Mkiv Supra TT and I've personally worked on at least a hundred Mkiv TTs (yep, I can provide references). I bet I've changed at least two dozen Mkiv TT clutches all by myself, and I've had four different clutches in my own Mkiv Supra TT. I have personal experience driving (and in most cases also installing) almost every clutch that's on the market for the Mkiv TT. Again, you can depend on no BS from me, but sometimes the truth can hurt.
Phil '94 Supra Turbo, 6spd, 'APU'+ Displacement is no replacement for boost. Life begins at 30psi. NB: Please consider posting any help requests in a new thread instead of asking me for help privately. About 99.9+% of the time, private help requests end up covering great information that could be very valuable to other forum members. If you have a good reason for needing the help request to be private, I'll consider it. If not, then why not give everyone else the opportunity to pitch in too, and/or learn from the information? Remember, there's no such thing as a dumb question. We're all here to help within this family of Supra owners. Last edited by pwpanas; 08-31-2007 at 01:57 AM. |
HElp with sports clutch!! | whitequasimodo | MKIII Supra | 3 | 05-07-2008 11:06 PM |
Clutch Troubleshooting | ivire | MKIII Supra | 9 | 11-09-2006 01:29 AM |
