Old 09-08-2007, 04:54 PM   #1
amin
amin is on a distinguished road
Default Converting NA to Bostlogic stage 1 turbo. need help
I have 93 supra NA automatic with 150k on it and getting deals on making it a single turbo. I am considering boostlogic turbo kit ($4499 + $1775 installation). what do you guys think should I go with boostlogic turbo kit or not. I am getting it from suprastore.com.
My concern is car is automatic. Is it worth to do that or should I look around somewhere else.
my budget is to be done not more than $7k.
thanks
amin is offline   Reply With Quote
Old 09-09-2007, 02:23 PM   #2
pwpanas
Supra Owner
pwpanas's Avatar
my budget is to be done not more than $7k...
I think it's a very worthwhile project, as long as the shop doing that installation for $1775 is very experienced working on the Toyota Supra.
When I say worthwhile, I know you'll produce the power you're looking for. What I can not promise you is whether or not your oem n/a auto tranny will hold up. The guys at Boostlogic can tell you for sure.
Also, why don't you buy directly from boostlogic?
Life begins at 30psi.
Old 09-20-2007, 07:05 AM   #3
supraman121
http://www.boostlogic.com/xcart/home.php?cat=19
It the same price from there website $4499 but he could spend an extra thousand and get the stage 2 for $5249
Magnaflow exhaust NO KAT
K&N Air Filter
www.myspace.com/coreyjstevens
Old 09-20-2007, 08:29 PM   #4
supra_91
supra_91's Avatar
the N/A tranny can only take so much
Old 09-21-2007, 02:22 AM   #5
supraman121
Its an na-t conversion kit, they would list if you need to have a tranny upgrade if you need to upgrade the trans, but sence its a na-t conversion the original trans should work.
K&N Air Filter
Old 09-26-2007, 01:19 AM   #6
Godfather MKIV
Godfather MKIV's Avatar
Godfather MKIV is on a distinguished road
i have the BL stage 1 kit and heres a few things i had to do...for one...expecially with the age of your tranny (mine was 136k miles) you need a upgraded tranny...mine lasted 3 months before it started slipping 2nd gear and another thing is if your looking to go any further than the 280whp you need a new headgasket...it was fun at first but once i realized i couldnt boost more than 9psi without a headgasket i had to upgrade...but those things arent too much...it cost me 1700 for a built BL tranny (got it on a for sale listing) and 230 for the 2mm headgasket and anothern 130ish for head studs and a map-ecu for 400.
so if your going NA-T, you might as well budget for the tranny, headgasket, maf transulator or map-ecu, and head studs to complete the transistion.
'94 black on black auto MKIV
project started june 1st 2006
http://www.cardomain.com/ride/2374205
Godfather MKIV is offline   Reply With Quote
Garrett turbo question GARRETT T3/T04E TO4E 60 Trim Stage III Turbo Burning Pyro MKIII Supra 1 10-24-2007 09:29 PM
