I have completely restored my 1993.5 Supra, EVERYTHING has been done and works great except that damn dome light. It keeps burning bulbs (sylvania 55) The bulb it is supposed to take ia a DE3175 which DOES NOT fit. I don't even know what the proper bulb is. Should I try to find a replacemnet module, can this be repaired, DON'T KNOW WHERE TO BEGIN Other than that one set of bulbs, car is pretty nice. (added Powerhouse Racing G60 Single turbo, replaced interdooler, added Millen race chip/module, 3"downpipe, Lots of HKS including exhaust. About 580 HP) Can any body help?
http://www.toyota-supra.info/forums/...tid=1043&stc=1 Last edited by jdbones; 09-10-2007 at 05:38 AM. |
it looks nice when the outside is kept clean with no body kit. you did a good job
91 N/A automatic supra;K&N FIPK;2.5" custom exhaust;no cat;pacesetter header;eibach springs;tokico "blues";MKIV TT rims |
Well, I fixed my dome light. First take off the plastic cover plate, then there are two screws that screw into to top, removed them and entire dome light falls right out. As soon as it did I saw the problem. There are a lot of wires in a small area and two of the wires, where they are soldered were touching. I unsoldered them, resoldered them and used some shrink tubing to avoid further contact. The lights work great. Delay off works, they work together or separately and work in the "door open" or off position. Congratulations to me. My cost $0.00 !!
#4 | |
![]() Quote:
Phil '94 Supra Turbo, 6spd, 'APU'+ Displacement is no replacement for boost. Life begins at 30psi. NB: Please consider posting any help requests in a new thread instead of asking me for help privately. About 99.9+% of the time, private help requests end up covering great information that could be very valuable to other forum members. If you have a good reason for needing the help request to be private, I'll consider it. If not, then why not give everyone else the opportunity to pitch in too, and/or learn from the information? Remember, there's no such thing as a dumb question. We're all here to help within this family of Supra owners. |
I like the car... not the fake hood scoop so much, that doesnt mean go get a real one it means the car looks even better without a hood scoop better yet get the carbon fiber hood it would look really nice.
Upgrades- 225/50/R16's Kumho ECSTA AST (KU25) 273 bucks with shipping Magnaflow exhaust NO KAT K&N Air Filter www.myspace.com/coreyjstevens http://vids.myspace.com/index.cfm?fu...oid=1536317037 <------ this one should work check out the accident one aswell ya i might be a "fat kid" but i sure can move fast!~ |
#6 |
SUCCESS
After reading how soldering was required and also reading somewhere else that someone inserted a screw somewhere, I took my battery charger, attached the negative to one connector terminal and then started there, Immediately I found the problem. One of the terminals on back of the unit was no longer connecting to the wire underneath! It looked perfectly normal but if I touched power to the center of the solder it lit up, but if I touched the power to the tab that was connected to the solder and has the tab that goes in the connector, no light! So I new this was where the solder was somehow not connecting. I was lucky in that it was the first contact point I checked. It might be the very weak spot on all these dome lights or you might have to test and search for yourself to see if you have a bad soldered connection on your light assembly. Remember they will appear to look perfectly connected and soldered! I didn't feel like searching for solder and my soldering gun. I have not soldered anything in many years and as I recall I sucked at it. So I got my drill and a small drill bit and I drilled the solder out. I then needed to be lucky enough to find a nice small tapered metal screw that I could use in place of the solder. My first thought was.... McDonalds Happy Meal toys! I had to look pretty good to find a small happy meal type toy that had a phillips head instead of the weird triangle screw head. I found an Easter Toy that once topped a plastic container of candy. I pulled the bunnies screws and Whallah I had a screw that would work. I ran the screw through the open loops left by the solder being drilled out. I tested the light and it worked fine! I installed the light back in my Supra and so far so good. Of course I can solder it later if this does not hold but I took some pics for you guys because no one had actually shown what they did. Check out the 2nd pic to see the screw ran through the connector tab and into the eyelet on the other side that is attached to the positive input lead. Almost ready for Inspection this was a big one just for my own enjoyment of the car. Can't live without an interior light when you have a 7 year old daughter. Will buy some cheap horns from Auto Zone tomorrow. Cost of repair???? One Dismembered Easter Bunny! Thanks for reading this post. Scott ps I put the Easter Bunny back together with one screw and he is recovering nicely!
1987 N/A 7MGE Left Hand Drive MK3 Red 5 Speed and Black Auto Supras My Next project is the Batmobile! Last edited by batmmannn; 06-05-2010 at 09:54 AM. |
88 supra dome light removal help | Jjona5 | MKIII Supra | 3 | 09-04-2014 06:10 PM |
light on dash that tells you a light is out | D_Train | MKIII Supra | 7 | 08-04-2007 05:10 PM |
dome light issues | Supra2NR | Non-Generation Specific Questions | 7 | 05-04-2006 04:06 AM |
battery warning light / tail lamp failure warning light | MattJ | MKIII Supra | 5 | 02-06-2006 07:22 PM |
