Old 06-09-2005, 04:08 AM   #1
87SupraChick
87SupraChick is on a distinguished road
Ok still wont start timing is now correct paid a mechanic to set it Discovered my oil pressure gauge isnt reading and its not the gauge how do i check/correct this??
87SupraChick is offline   Reply With Quote
Old 06-09-2005, 08:52 AM   #2
suprra_girl
7M POWAH! ;)
suprra_girl's Avatar
ok... we'll keep to one thread now eh
first off... when did this start.. (the not starting thing)
is there anything you changed or did, oil change, plugs etc
list everything you have checked/tried/diagnosed to get this going
oil pressure gauge not reading at all... maybe the plug has come off the oil pressure sender unit
is yours turbo? i can't remember..
Pics of my build.
Do a diagnostic first!
Old 06-09-2005, 05:56 PM   #3
KingDiamond
KingDiamond is on a distinguished road
yeah she might be thinking there is something wrong because the gauge is reading low. And everything she has done will definately help.
KingDiamond is offline   Reply With Quote
Old 06-09-2005, 09:56 PM   #4
87SupraChick
Tis not a turbo and no its not reading low it doesnt read at all i replaced the head gasket technically ive never heard the car run i bought it with a blown head gasket but it ran shortly before i bought it
Old 06-09-2005, 10:29 PM   #5
KingDiamond
is the timing belt setup properly?
Old 06-10-2005, 12:12 AM   #6
jza80 Supra C-I TT
jza80 Supra C-I TT is on a distinguished road
i'm just about confused about every thread here... what does a timing belt do?
[img]http://rds.yahoo.com/S=96062883/K=supra+logo/v=2/SID=w/TID=I001_70/l=IVS/SIG=127fv51d7/EXP=1118546922/*-http%3A//www.supra.racingteam.kessler.com.pl/logo.jpg[/img]
<span style='color:green'>300 horsepower is 299 too much for any camaro</span>
MKIV POWER *cough* suprra _girl *cough cough*
jza80 Supra C-I TT is offline   Reply With Quote
Old 06-10-2005, 07:06 PM   #7
KingDiamond
well your engine needs the timing belt to be setup correctly so that the valves open and close at the right time. if your timing belt is off, and your exhaust valves are open during the compression stroke, your not gonna build any compression. You would have had to take the timing belt off to remove the head to do the headgasket. If you have a manual it will show you wheer the marks on your cam gears should be sitting for proper timing belt installation, and your crank should be at 0 degress top dead center(someone can correct me if i am wrong on that one). Does the engine sound like its cranking real fast, or does it sound like its cranking improperly at all, or does it sound normal?
Old 06-10-2005, 08:31 PM   #8
ddmcse
ddmcse's Avatar
here is how i set the timing :
i pull spark plug number one and slide a long chop stick down into the cylinder then i turn it over by hand watching the stick go up and down (jesus make sure the stick is long enough ). when it's at the top i check the timing marks and adjust for 0 .then i adjust the cams so the notches on both are at 12 oclock . bolt in the cam sensor or the distrib and guestamate the position for it .
just setting the timing isn't good enough you will most likely need to adjust the distrib and you may need to twist it one way or the other to get it just right if it won't start . it's crucial that the distrib or sensor is place into the block at just the right angle
i'll point you again to the page suprra_girl pointed you at . this is for installing the distrib
http://www.cygnusx1.net/supra/library/TSRM...M/ig/IG_19.html
step b is what you need to get right . even with the timing set correctly you could spin it over all day and get nothing without this distrib being in right
so once you set the timing ..the timing is set . it doesn't change if you try again tomorrow .
you need to try and twist your cap/distrib a little and turn it over , no dice try another twist same direction but a little further , still nothing try the other direction
worry about an oil gauge after you get it started
300+ RW HP Dyno run,
Blown HeadGasket info
My Supra KiXGaS
Old 06-11-2005, 03:07 AM   #9
jza80 Supra C-I TT
what is compression, headgasket, and what happens when u crank something. also when u are driving automatic what is different from manual. i'm talking technical. is there more parts?
Old 06-13-2005, 11:14 AM   #10
87SupraChick
Nope timing is correct had a mechanic come out and double check it he was stumped to we ran advanced diagnostic on it and got about 12 codeds saying various circuits were open but no trouble codes were actually stored were thinking ECU All t he fuses and relays are good ive replaced most everything in the ignition system but my oil gauge wont even register but then again it hasnt started since i bought it with a blown head gasket but it ran before the gasket blew
7MGE oil pressure Arne (Denmark) MKIII Supra 14 07-31-2009 10:07 PM
Oil Pressure Sender!? spudz29212MKIII MKIII Supra 8 05-06-2008 01:41 PM
Fuel pump relay and pressure. carfanatic89 MKIII Supra 8 05-01-2008 06:39 PM
Tire pressure? dannydavi Non-Generation Specific Questions 11 08-16-2007 06:03 AM
oil pressure johnkarl MKIII Supra 2 11-05-2006 02:11 PM
