Old 01-18-2008, 04:21 AM   #1
Jbone7
Jbone7 is on a distinguished road
Default Found Supra does this sound resonable?
its got a new rebuilt motor with only about 5000 miles on it. the body has 120000 miles and there are lots of new parts. its got a removable hard top (targa top). no no rust or leaks of any kind. i am selling the parts car with it so the total cost is $4500 but the parts car is no charge. the good supra has new brakes and tires on it only as many miles as the motor. the motor is bored 40 over and has a new alternator and motor mounts. all the manual conversion parts are going with it in the parts car too. new spark plugs, wires, rotor, new fuel injectors, with new hardware on the fuel rail. all new gaskets and seals. hks head gasket and arp head bolts. also has new muffler. the car is pushing about 220 to 240 hp. there are no problems with it and i am selling because i am going to school and need tuition money. i have owned it for about 1.5 years and only drove it a couple of months. it never touched snow or salt. always stored in the garage.
hope this helps you out alot and please let me know what you are going to do thanks.
Name:	Car in brookfield.jpg
Jbone7 is offline   Reply With Quote
Old 01-18-2008, 04:01 PM   #2
Pretaco
Drive it.
Have a mechanic you trust check it out, top and bottom.
Have your mechanic trest drive it.
Have your mechanic do a block test and a compression test on it.
There is a thread around here about what to look for in a used car, find it and do all that stuff.
Extra parts are good if you have a place to store them, and if you have the tools and ability to replace them, otherwise they end up just taking up space, but you can sell them and try to make some of your money back.
Ray.
Currently Running Good
Mint 1989 supra found. Need quote on re-torque whowouldfigga Non-Generation Specific Questions 2 02-05-2008 01:57 PM
Found a supra critterCQB MKIII Supra 5 10-19-2006 03:28 AM
Found a cheap supra, need help. bigyfsair Non-Generation Specific Questions 7 02-12-2006 08:12 PM
Found a Supra, asking for some advice! Deadtoday Non-Generation Specific Questions 14 05-30-2005 04:04 AM
