Old 01-19-2008, 09:59 PM   #1
smokinsupra
smokinsupra is on a distinguished road
Default help please / short circuit ?
Im new to this site, but I have a 87 Supra / non-turbo/5 speed ... it seems like every time i fix something, something else goes wrong. Well this time my lights went out, only my head lights work and brake lights when i apply the brakes. I found the burned fuse, its a 15 so i went ahead and replaced it w/ a 15 and it blew that one. so i put a 30 and it worked except for my turning signals, but then i heard it can cause a electrical fire. Like everyone, im low on cash..... how can i find the short myself? Thank you - Ken
smokinsupra is offline   Reply With Quote
Old 01-21-2008, 02:43 PM   #2
Pretaco
Pretaco is on a distinguished road
Which fuse is the one that keeps blowing up?
You probably have a shorted light bulb, or corroded ground somewhere in that circuit. If its the taillights, and you have an aftermarket stereo, its probably the wire for the interior light that goes to the stereo that is shorted out.
Why don't your turn signals work? Is that also a fuse problem, or switch, or hazard switch or what? It could be related and help you find your other problem, or it could be competely different.
Ray.
'88 Supra Targa 5 speed w/ '90 7M-GTE
Currently Running Good
For Sale: Light blue body parts, Blue interior parts all from '90 supra targa turbo manual.
Also for sale: R154 trans, brake pedal, master cylinder, booster, abs actuator, sensors, abs ecu, driveshaft, 3.90 lsd rear end, radiator, wiring, speedo cable, 8 saw blade wheels, '88 ecu, relays, cruise control actuator (bad cable), empty fuel tank, etc....
Pretaco is offline   Reply With Quote
Wiper fuse short? kewlcoconut MKIII Supra 10 02-27-2007 04:43 AM
Short Circuit In The Trunk jaysun MKIII Supra 0 06-03-2006 11:13 PM
Distributor Circuit Problems nickvash0104 MKIII Supra 3 04-03-2006 12:01 PM
Short Shifter?! 88Supraboy MKIII Supra 4 12-01-2005 09:13 PM
