Old 04-06-2008, 10:09 AM   #1
Rowan_supra
Rowan_supra is on a distinguished road
Default windscreen wiper promblem
i can pull on the wipers and they go across but no water comes thru the lil jets and i know they did work i have checked fuses connections to the motor and also the tubes that run to them and filled it with water and it still not workin any ideas
Rowan_supra is offline   Reply With Quote
Old 04-09-2008, 01:28 AM   #2
Busted Knuckles
Busted Knuckles's Avatar
When I first got my Supra, the washer nozzles did not work. But, I could hear the motors running when I pressed the buttons (one for the windshield, one for the rear glass). When I pulled the motors out of the reservoir, and they are held in simply with grommets, I found the bottom of the reservoir was plugged with sediment and dirt. I cleaned it out, and now they work just fine. BTW, on my '88 MK III, both motors plug into a common reservoir.
Old 04-09-2008, 10:39 AM   #3
Rowan_supra
Default cheers for opinion
i'll have a gander saturday thanks man
Mk III Antenna,rear wiper motor, read lock non-functional. Advice needed finaltable Non-Generation Specific Questions 4 07-20-2007 01:06 PM
wiper arms??? kidthunder650 MKIII Supra 1 06-27-2007 02:46 AM
Wiper fuse short? kewlcoconut MKIII Supra 10 02-27-2007 04:43 AM
1987 Supra Turbo wiper blade arms vancouver874 Non-Generation Specific Questions 2 08-18-2006 11:42 PM
