#1 |
i can pull on the wipers and they go across but no water comes thru the lil jets and i know they did work i have checked fuses connections to the motor and also the tubes that run to them and filled it with water and it still not workin any ideas
#2 |
When I first got my Supra, the washer nozzles did not work. But, I could hear the motors running when I pressed the buttons (one for the windshield, one for the rear glass). When I pulled the motors out of the reservoir, and they are held in simply with grommets, I found the bottom of the reservoir was plugged with sediment and dirt. I cleaned it out, and now they work just fine. BTW, on my '88 MK III, both motors plug into a common reservoir.
#3 |
i'll have a gander saturday thanks man
Thread Tools | |
Display Modes | |
Mk III Antenna,rear wiper motor, read lock non-functional. Advice needed | finaltable | Non-Generation Specific Questions | 4 | 07-20-2007 01:06 PM |
wiper arms??? | kidthunder650 | MKIII Supra | 1 | 06-27-2007 02:46 AM |
Wiper fuse short? | kewlcoconut | MKIII Supra | 10 | 02-27-2007 04:43 AM |
1987 Supra Turbo wiper blade arms | vancouver874 | Non-Generation Specific Questions | 2 | 08-18-2006 11:42 PM |
