Old 04-14-2008, 04:04 AM   #1
robwpe
robwpe is on a distinguished road
Question security alarm
Son in law set off the alarm in his 1986 1/2 Supra. He got it cancelled, but the starter wouldn't crank. Its a 5 speed, and I have him a shove and it took of and ran ok. Question, does the alarm only keep the starter from getting current, or did he just happen to have a starter problem at about the same time
Hiflier
1989 Supra Turbo
Brown with tan interior
139,000 miles. New Head and Gasket, new radiator, water pump, power steering pump, plug wires and igniter
robwpe is offline   Reply With Quote
Old 04-14-2008, 11:03 AM   #2
scruffboy
scruffboy's Avatar
Default Common problem
I think almost every MKIII Supra owner has experienced problems with the factory alarm. I got this trick from a decent mechanic at a Toyota dealership. If the alarm won't let you start the car, insert the key into the door and turn it twice to the right. That should reset it. If it doesn't work, try the passenger door, as it gets key opened much less and will have less wear. I swear this works. I have done it several times.
Good Luck, Scruffboy
The only way they'll get my Supra is to pry my cold, dead fingers from the steering wheel.
89 N/A Supra, 5 speed, TEMS, Moon Roof, all stock, Black with beautiful Burgundy interior, lots of new parts, oil changed every 3 months like clockwork.
Old 04-14-2008, 03:03 PM   #3
robwpe
Smile alarm
Thanks for the reply. I was thinking that if the alarm was keeping the starter from getting current, It would also kill the ignition. Can't find much about what all the alarm does in the repair manual. However since we rolled the car and got it started, it must not cut off the ignition, or he just has a starter problem at the same time.
Hiflier
1989 Supra Turbo
Old 04-14-2008, 11:09 PM   #4
Busted Knuckles
Busted Knuckles's Avatar
Try the key trick first. I set off the alarm on my car after accidentally locking the keys in. I don't remember if it turned off when I tried to start the car, but I do know it would not start until I unlocked the driver's side door. After that, it was fine.
Old 04-15-2008, 02:18 AM   #5
robwpe
Smile Supra alarm
Thanks we'll try that again, and from both doors. If no change, we'll pull the starter and check it our, or if we can get to it with some jumper cables, we'll see if its getting voltage or not
Hiflier
1989 Supra Turbo
Old 04-15-2008, 11:19 PM   #6
Busted Knuckles
Also, check the post for 'Alarm System' in 'Supra FAQ'. Here's a quick link: http://www.toyota-supra.info/forums/...rm-system.html . If you read through it, and look at the wiring diagrams, you'll see that the security system does only interrupt the starter circuit by ungrounding the relay. That's all it does. It does not interrupt the ignition circuits at all. I hope the key trick worked.
trouble with security system derekrd Non-Generation Specific Questions 4 06-05-2013 07:05 PM
1989 Supra alarm help... :( sizzor Non-Generation Specific Questions 8 11-07-2009 05:30 PM
alarm? starter? dunno help plz Scionguy MKIII Supra 3 11-04-2008 08:35 PM
Car alarm with a mind of its own suprascoot MKIII Supra 10 03-08-2008 11:09 PM
Alarm MICAHMOBERLY Non-Generation Specific Questions 5 08-27-2006 10:00 PM
