#1 |
I bought some of the Valvoline Dura blend simi synthetic formula gear oil. I have heard some synthetics are ready for use in a LSD with out the additive is this true? My next question is the valvoline ready or does it need the additive, it says on the bottle for conventional or LSD differentials and gear boxes. Will I need an additive? Also What does the additive do any way?
#2 |
It appears by the label (and many oils come ready for LSD), implies you can put it in without additive. This is probably true.
The additive was needed for the regular oil to allow a little more 'slip' of the clutches (inside the diff) when making turns. So it wouldn't 'chatter', and wear out the clutches early. If your diff has never been rebuilt, with new clutch pack, then the LSD is probably not working (worn out) anyway.
Had a Red 1989 N/A. Automatic. Sports Pkg. w/wing. TEMS, and some nice MODS. Sold to a friend 10/08/08. |
#3 |
Where does a fella get a new clutch pack? I try to avoid dealers whenever I can to avoid markup. Any online suppliers?
1988 Supra - N/A 5 speed 1974 'Cuda - 318 2001 Cherokee |
#4 |
Rebuilding a LSD diff is not something you will do in the garage. They have to be set up correctly, or you just blew a wad of $$.
You can find rebuilts on the net. The TSRM tells you how to do it.
Thread Tools | |
Display Modes | |
speedometer drive gear removal | Gunnar | MKIII Supra | 1 | 01-20-2008 08:24 PM |
quick question | blacksheep | Non-Generation Specific Questions | 10 | 01-01-2007 08:19 PM |
lower timing gear | quamme | Non-Generation Specific Questions | 0 | 12-12-2006 12:41 AM |
Second Gear Sound | dcrusupra | MKIII Supra | 9 | 12-24-2005 08:05 AM |
2nd gear grind | Chomper | Non-Generation Specific Questions | 1 | 12-14-2005 03:59 AM |
