Old 05-03-2008, 09:21 PM   #1
occsupra
occsupra is on a distinguished road
Default I need help. is it fuel or electrical?
Brought the 1987 non-turbo to the Toyo. dealer because the engine will not rev pst 3500 rpm. Stops at the exact same spot every time. Kinda like it would with a governor.
So dealer told me to replace the plugs and wires...rotor and cap. I just did that. Idles really nice now...but same problem. Runs great all the way up there..but then stops...
Can someone help me? Ever occur to anyone out there before?
cheers
Nigel
occsupra is offline   Reply With Quote
Old 05-04-2008, 02:34 AM   #2
mrnickleye
mrnickleye's Avatar
If it were mine, and I thought the fuel filter had not been changed in a long time, I would change that now.
Old 05-04-2008, 12:24 PM   #3
Busted Knuckles
Busted Knuckles's Avatar
I'd also check the linkage to the throttle body. It may be damaged or way misadjusted. If the throttle body opens completely, I'd suspect fuel problems.
Old 05-04-2008, 01:35 PM   #4
occsupra
Default Thanks
Thanks for your input! I am going to start with the throttle linkage, then change the fuel filter. Hopefully this clears up the mess.
regards
Nigel
Old 05-07-2008, 05:32 AM   #5
87MGE
87MGE is on a distinguished road
Default I Sorta had that problem
my 7m n/a idled smooth, and i could rev it high, but it had this little thing that at if i were to hold it anywhere from 2000-2500 the rpm would drop to 1200, I had changed everything on the car except the fuel filter. i ordered it and replaced it. the problem went away. and idles way way smoother!
*86.5 N/A
*Fully Rebuilt Engine
*Port Polished Head
*Painted Wheels
MODS TO DO NEXT: (in order)
-Eibach Lowering Springs
-Tokico Struts
-Sway Bars
-Headers
-3 in. Piping
-Cold Air Intake
-Wheels
87MGE is offline   Reply With Quote
supra head gasket questions+ rebuild Andy C MKIII Supra 169 05-18-2010 01:59 AM
Fuel pump relay and pressure. carfanatic89 MKIII Supra 8 05-01-2008 06:39 PM
car cranks, but no fuel or spark mustangtw5901 MKIII Supra 17 04-30-2008 07:48 PM
Fuel issues!! teedoff00 MKIII Supra 1 01-01-2008 05:09 AM
Testing for bad ECU, &/or bad Fuel Pump elliotl MKIII Supra 0 08-21-2007 10:42 PM
