Old 05-13-2008, 01:39 AM   #1
mastergrader007
mastergrader007 is on a distinguished road
Default stock boost psi??
Hey,
I have an 88 supra turbo bone stock my boost gauge only goes to +4 and i only make it half way between 0 and +4 (so it would be 2 psi with my calculations) does that sound right???? im new and lost
thanks for the help
mastergrader007 is offline   Reply With Quote
Old 05-13-2008, 02:14 PM   #2
j3pz
only goes up to 4? doesnt soiund right, all the ones ive seen go up to 8psi. stock pressure is like 5 or 6 i believe
Old 05-13-2008, 02:36 PM   #3
mastergrader007
i thought is was funny that it only went to +4. so i guess im only getting 2psi of boost. that sucks. i will have to check my piping i guess. the only good thing is that this means my car should be EVEN FASTER than it already is. thanks
Old 05-15-2008, 06:19 AM   #4
j3pz
hmm you sure the gauge is read in psi? also start the car and listen under the hood for hissing. im suspecting a boost leak. you could build a boost leak tester if you wanted to.
Old 05-15-2008, 07:13 AM   #5
azerty
azerty's Avatar
azerty is on a distinguished road
Are you sure you have done the conversions roght?
On the stock gauge, +4 means +10 psi.
So if you have disabled your fuel cut defender, you should be carefull when messing up with the boost
1988 yelow manual turbo targa
HKS ssqv bov
Hose Techniques silicon hoses
Forge manual boost controller
boost gauge
K&N FIPK
ACT clutch kit HD-G6
Fidanza lightened flyweel
550cc RC Injectors
255lph Walbro Fuel Pump
LIPP Lexus AFM Replica
3" turbo back echaust with divorced
downpipe and no cats.
Aeromotive FPR
Aem Uego Wideband Gauge+O2 sensor
azerty is offline   Reply With Quote
Old 05-15-2008, 10:33 AM   #6
mastergrader007
Default Doh!
im an idiot!! its not measured in psi its measured in mmhg. i guess i should pay more attention! thanks everyone for the help
Boost and Stock Fuel collink MKIII Supra 5 03-26-2008 11:43 PM
How much boost could you run on stock 7mge internals? supraman121 MKIII Supra 2 02-22-2007 11:46 PM
How much Boost on Stock Internals? abhattan MKIII Supra 26 02-20-2007 06:30 PM
boost on stock with ct26? carlosemagana MKIII Supra 8 12-31-2006 07:48 AM
stock boost drgnframe24 MKIV Supra 5 08-26-2006 04:12 PM
