Old 05-28-2008, 02:36 AM   #1
supra_chick_1987
supra_chick_1987 is on a distinguished road
Question Radiator Blew Up!!! Help!!!!!
For the past two years, i've been having a TERRIBLE time with my 1987 supra....non-turbo, automatic. First it was running hot, but then i replaced the fan clutch and the thermostat, and that seemed to fix the problem.
After that, the temp. gauge would say it was within normal range, but when I would kill the engine, you could hear (and see, when you looked in the coolant resevoir) it boiling. Also, I had to add coolant quite frequently.
Today, I drove at around 45 mph for 35 or 40 minutes...when I stopped the car, I noticed a small amount of steam coming out from under the hood, and the radiator spilled coolant all over. After it had cooled for several hours, I put in water, then started the car. Just idling, the RPMs slowed, slowed some more, and then the car sputtered and started to die (I killed the engine by that point).
Tomorrow, I am going to get a new radiator. Do you think this is the problem? Any suggestions?
PLEASE HELP!!!!!!
supra_chick_1987 is offline   Reply With Quote
Old 05-28-2008, 02:47 AM   #2
STORMINB01
STORMINB01 is on a distinguished road
Default Hot Hot Hot
If the new radiator does'nt work for you, you may need a head gasket. I have a mechanic in marrieta ga if you need one.
STORMINB01 is offline   Reply With Quote
Old 05-28-2008, 04:01 AM   #3
Unless your radiator is cracked (and you can see it), then first have a block test done to see if the headgasket is bad. Or if they do smog tests there, they can 'sniff' the radiator at the open can during idle to see if HC's are present,= BHG.
