Old 08-28-2008, 02:17 AM   #2
mnewxv
mnewxv is on a distinguished road
Originally Posted by fienloco View Post
Ok I have looked through the TSRM troubleshooting and it doesnt elaborate on something as simple as no BOOST!! Stupid ? Can anyone tell me why? What to look at? Where I can find the problem?? It is a swap from JapanRacingEngines. Brought from overseas supposedly. I have done a head gasket I have changed all the sensors from thiers to my origanals of course only the ones on the engine, the wiring harness, you name it. I have either touched on it or replaced it. Got her timed 10 degrees before TDC. I have also replaced the boot between the MAS and the turbo as well as the other lines that run off of it. Compression is good. Cooling system resolved so far. Vacuum seems to be ok. I want to know why the turbo is not creating boost??...... I have spent hours on hours and cash over cash to make her run right and do whatshe is supposed to. Help me please a pro someone anyone who can tell me where to start. Also. What vacuum lines runs where and to what? <87 7-MGTE Manual> I was told by someone something about a boost controller on a wheel well. I have looked and do not find it. I need to resolve this issue. Anything helpful hit me up. PLEASE!!! She runs like a 7-MGE I miss the hiss!
so if you pop the hood revving is the turbine spinning? check if its seized up. you sure the boost gauge is hooked up and functional?
mnewxv is offline   Reply With Quote
low boost psi, wtf supradad86_5 MKIII Supra 4 02-09-2014 02:05 AM
wont hold boost Supraman MKIII Supra 12 04-19-2007 04:52 AM
issue w/ boost spikes? i think? NOTORIOUS VR Non-Generation Specific Questions 17 01-17-2007 08:35 PM
installing manual boost controller 1989?? hamburgler MKIII Supra 4 07-13-2005 12:55 PM
No boost in neutral but boost in gear! edgardo MKIII Supra 5 10-09-2004 04:01 AM
