Old 09-07-2008, 10:19 AM   #1
Bill UK
AEM EMS
Bill UK's Avatar
Default Expansion Tank Levels
Probably a bit paranoid about the coolant expansion tank levels, like most of us who have had their fair share of BHG`s. I haven’t found any information relating to what should be the normal increase in level after an average journey, (if there is such a thing). So lets say the thermostat, water pump, radiator, rad cap, fan etc are all working correctly, what would you expect the level to be increased by from a cold start up to the end of 40 mile trip. This obviously depends on county, climate, altitude and driving conditions. In theory water expands with temperature the nearer the boiling point the larger the increase in volume. Can anyone give me some increase in levels on their Supra?
Old 09-11-2008, 03:22 AM   #2
fienloco
fienloco's Avatar
fienloco is on a distinguished road
Say there. I noticed the same thing you are concerned about today on my 87 MKIII. I just did a HG. Went for about a twenty mile drive got home looked at the expansion tank it was high let her cool down and she dropped down to its normal level. If that helps. My gauge does not read hot either. So Im guessing it is somewhat normal. So do you know what the beginning of a clutch failure feels like?
fienloco is offline   Reply With Quote
Old 09-11-2008, 06:57 PM   #3
Bill UK
AEM EMS
Bill UK's Avatar
Thanks for the info, that sounds reassuring. Like you I've just done a HG replacement, no gurgling noise behind the dash at start up,the expansion tank coolant rises about ? to ? of an inch after a 40 mile trip (with moderate boost) Left over night and the coolant is sucked back into the system as it should. I put the expansion tank in the dishwasher to give it a good clean and marked the max level with black marker pen, probably should have left it dirty then I wouldn’t have noticed the level increase. Your question about the clutch; one way to test a slipping clutch is to drive up a hill and accelerate hard and see if the speed increase in relation to the rev`s, or on a flat road put it into say 4th about 30 miles per hour and accelerate hard, if its slipping the revs will increase but the speed will marginally increase. If you smell something burning it will most defiantly be the clutch.
Slow Bubbles Into The Resevoir Tank Drag0na5h MKIII Supra 2 03-18-2008 05:37 PM
Overflow Tank D_Train MKIII Supra 1 03-21-2007 02:52 AM
gas tank leak burton51m MKIII Supra 14 11-24-2006 06:16 PM
WAter not going back to raditor from recovery tank Help Jeff_5_7 MKIII Supra 12 09-15-2006 03:49 AM
WAter not going back to raditor from recovery tank Help Jeff_5_7 MKIII Supra 0 09-07-2006 02:05 AM
