Old 10-06-2008, 04:36 AM   #1
SupraSean
SupraSean is on a distinguished road
Default ECT Transmission?
Ok, i know a decent amount about supra's but i still have not figured out if there is an actual difference if the ect is on or off, it seems like its slighty quicker on the acceleration but i cant tell for sure, can someone plz tell me what the stupid button actually does? thx
SupraSean is offline   Reply With Quote
Old 10-07-2008, 12:51 AM   #2
Supra Greg
Supra Greg's Avatar
Supra Greg is on a distinguished road
leave it off... from stand still take off..put pedel to floor and watch were tach shifts at...
turn on... repeat step 1...
Supra Greg is offline   Reply With Quote
Old 10-07-2008, 04:13 PM   #3
SupraSean
so basically all it does is hold it in gear longer?
Old 10-07-2008, 08:15 PM   #4
Supra Greg
Supra Greg's Avatar
far as i can tell... with it off it shifts lot quicker and smoother ... i leave it ON :} mine shifts around 5700.... with it on... forgot what it does with it off... somthing like 5000 i think
Old 10-08-2008, 02:31 PM   #5
SupraSean
wow thats weird, mine shifts around anywhere from6500 to 7000, which the rev limiter stops at like 7100 rpms, why do you think there different?
Old 10-10-2008, 11:13 PM   #6
suprra_girl
7M POWAH! ;)
suprra_girl's Avatar
I noticed the same thing with mine, it's the transmission starting to fubar
Moved to general
Pics of my build.
Do a diagnostic first!
Old 10-11-2008, 12:40 AM   #7
Supra Greg
Supra Greg's Avatar
whoes is starting to furbal ? mine are yalls ?
Old 10-11-2008, 03:20 AM   #8
suprra_girl
7M POWAH! ;)
Yours, just getting a little worn is all
Pics of my build.
Old 10-11-2008, 04:07 AM   #9
Supra Greg
Supra Greg's Avatar
Now i am talking about leaving in drive... not holding down in 1st....
Old 10-11-2008, 05:09 AM   #10
suprra_girl
7M POWAH! ;)
Yes, if you are throttling in D and it does not change before 5500rpm it is starting to wear.
and your rev limiter on your 7mgte/7mge will be at a max of 6750 on the 6M crank which revs higher than the 7M crank unless of course you have an aftermarket ecu to which you have adjustable rpm limiter.
Pics of my build.
1986 Turbo Automatic Transmission Rebuild? professorbob MKIII Supra 2 01-26-2012 01:06 AM
86.5 auto transmission removal HELP!!! elmer MKIII Supra 13 04-06-2010 10:41 PM
Should I try to rebuild my transmission, or leave it to experts? Busted Knuckles Non-Generation Specific Questions 1 04-15-2008 01:20 AM
Blown transmission 1985Supra MKII Supra 2 01-31-2007 07:56 AM
Transmission WiseAssJester MKIII Supra 4 09-26-2005 05:50 AM
