Ok so I just went and got a 1988 Supra Turbo and man was it worth it. So I used all the gas having fun and when it was time to fill up, the stupid gas tank lever won't open up the door. I was like WTF?!? I tried messing with the door itself but it's just making if worse and I can't seem to get that dang door open, any ideas?
#2 | |
![]() Quote:
LMAO
this is wat happened to me the first day i got mine! thank god i had my dad wit me at first i had to hold the lever and while i was, my dad had to push the door and den it opens but if u do wat mnew siad just pull that lever a couple of times and kinda hard but dnt break it lol but yeah it should start opening easily dats wat i did GOOD LUCK ![]()
~86 1/2 NA~ ![]() ![]() |
There's a rod that is on the latch that gets dirt grime in there - I sprayed it with some wd 40 and it works real nice now.
Passenger Door Wont Properly Lock | SideWinderGX | Car Audio and Alarms | 2 | 03-03-2009 09:08 PM |
Slow Bubbles Into The Resevoir Tank | Drag0na5h | MKIII Supra | 2 | 03-18-2008 05:37 PM |
WAter not going back to raditor from recovery tank Help | Jeff_5_7 | MKIII Supra | 12 | 09-15-2006 03:49 AM |
gas tank door stuck open | tonystarks | MKIII Supra | 1 | 05-18-2006 09:59 AM |
My Tricky Door Handle | DarkRaiderz | MKIII Supra | 10 | 11-21-2005 03:41 PM |
