#1 |
I've got a 1990 MK3 Supra with the 1G-GE engine. I've been trying to find the best spark plugs I can for it on NGK or Champion's website, alongwith other manufacturers, and they all seem to only list the 7M-GE and 7M-GTE engines.
Does anyone know for certain that the 7M-GE would take the same spark plugs as the 1G-GE? Haven't changed spark plugs in over 50,000kms, hoping to see a change in fuel consumption ![]() |
#2 |
Where did you find that one? I goggled it, and it is a 2.0L I6 engine used with less compression and power than the 7M-GE. Wikipedia did say some Supras used it. Wow
![]() I located a Toyota spark plug chart, and the 1G-GE engine uses the same BPR6EY-11 plugs the 1988-1992 Corolla with the 1.3L 2E engine uses. Here's the chart.http://monroesamara.ru/files/europe.pdf |
#3 | |
![]() Quote:
#4 | |
![]() Quote:
LOL, I know what it is, considering I have this engine in my car right now ![]() Thanks for that link, now I just need to figure out which plugs these are in the NGK or Champion plugs range ![]() |
#5 |
The chart IS NGKs. The order number is in the final column. That should help a great deal.
#6 |
Help! LOTS of oil on top of spark plugs | trevor217 | MKIII Supra | 5 | 12-17-2008 07:19 PM |
NGK Spark Plugs | 91 Supra | MKIII Supra | 5 | 08-07-2007 03:52 AM |
1986.5 with blown Head Gasket - Removing Spark Plugs | unkymurch | Non-Generation Specific Questions | 10 | 03-02-2007 06:48 PM |
Issues After Changing Spark Plugs | Getphazed | MKIII Supra | 8 | 11-03-2006 12:31 PM |
Spark plugs & WIRES | HEMAN | MKIII Supra | 2 | 11-03-2006 05:31 AM |
