-   Non-Generation Specific Questions (http://www.toyota-supra.info/forums/non-generation-specific-questions/)
-   -   Bought a MKIII blown engine (http://www.toyota-supra.info/forums/non-generation-specific-questions/1260-bought-a-mkiii-blown-engine.html)
zmatt 07-17-2005 02:03 AM
Well i got a 88 supra today and it has a blown engine. So i'm wondering what i should do.
Would you recomend a swaping an engine from another car or just fixing the dime size hole in the block?
Thanks any sugestions is greatly appericated.
this is a new world to me i'm a prelude owner so these engines are a bit different than the honda ones.
zmatt 07-17-2005 02:05 AM
Here is the engine.
http://ryzor.com/of/up/supra04.jpg
http://ryzor.com/of/up/supra01.jpg
Metalluthier 07-17-2005 07:16 AM
What exactly is wrong........besides "Blown".
Burzum - Det Som Engang Var
zmatt 07-17-2005 01:25 PM
The guy said there is a hole the size of a dime in the block.
zmatt 07-18-2005 06:57 AM
The engine was running perfectly before it blew. Anyone have any sugestions?
my friend said that his mechanic could do a cast iron weld on it? or sompthing like that
ddmcse 07-18-2005 11:21 AM
i think you're dreaming .
i'd plan to replace the engine .
do you really want to drive around with silly putty plugging a hole in the block ?
and what caused the hole to begin with ?
you're gonna have to pull the engine anyway
Metalluthier 07-18-2005 11:49 AM
No, never try to fix anything that way. If a real mechanic saw that car, he wouldn't think to weld it, he would REPLACE it. I bought a car with a cracked head once, and I later found out that the previous owner's mechanic welded it back up (Which never works) it caused engine damage. I almost wrecked into a truck when I was going 30mph and the engine decided to die. I love going 30 with no power steering or working brakes. Damn E-break never works.............
Replace the block
Graveland - Crown Heroic my Departure
zmatt 07-18-2005 08:18 PM
ok now i'm leanin towards buying this other car with the good engine in it and just swaping them.
suprra_girl 07-19-2005 10:41 AM
yeps 7mge engines are fairly cheap... or you could go the 7mgte swap way ;) turbos are more fun heh
and i wouldn't ever think of welding a block if it got a hole it in
replace the engine
what are the plans for the car? daily driver and racer? or just daily driver?
zmatt 07-19-2005 12:49 PM
I'm planing on making this a fast car not a daily driver or just fix her up and then sell for a profit. It all depends.
Is there anything that i would have to do to put a 7mgte engine in the n/a car?
