Old 11-24-2008, 04:41 PM   #1
ROSHIGAMI
ROSHIGAMI is on a distinguished road
Exclamation Major leak causing Overheating
ok so thanks to those who responded i found out that the cracked part i have IS infact the bigger portion of the thermostat housing. so now i need to get it replaced and get my electric fan hooked up and i'll be up and running once again.
ROSHIGAMI is offline   Reply With Quote
Old 12-04-2008, 01:22 AM   #2
ghost88
ghost88's Avatar
ghost88 is on a distinguished road
Default all i can say is...
i know that head gaskets are a common problem for supras because of factory torque settings being to low and head gaskets being cheap or old.
replace anything old - water pump/thermostat/head gaskets then try
again. if problem persists i read on another forum that the block may have to be checked. look for discolored oil and bubbles in the antifreeze. also make sure the fan shroud is still on.
anyway, hope this helps some, its the best i know. my supra overheated several years ago, i had no idea why, it was out of the blue, gaskets had went. i replaced them with steel reinforced gaskets and increased the torque settings.
ghost88 is offline   Reply With Quote
Old 12-04-2008, 11:03 PM   #3
ROSHIGAMI
ok cool thanks. i am in the process of getting the parts now.
Old 12-05-2008, 07:55 AM   #4
ghost88
ghost88's Avatar
Default also
i think the reason no one responded is because an overheating supra is like like saying why does it snow in winter, the cubs lose in the playoffs, or wheres the remote?. Everybody who owns a supra with over 100k miles (some less) is destined for a crash course in toyota cooling systems. You can also google "My 19## supra is overheating" to find fellow sufferers of BHG.
Old 12-05-2008, 10:51 AM   #5
ddmcse
ddmcse's Avatar
Cool Toyota Service Manual
Cygnus X1 - Supra
here you'll need this manual too.
MK2 TSRM On-Line
300+ RW HP Dyno run,
Blown HeadGasket info
My Supra KiXGaS
Heater Union (Coolant Leak) slader99 MKIII Supra 11 12-28-2009 12:29 AM
Coolant Leak bossman MKIII Supra 2 04-12-2008 09:31 PM
Oil Leak Question kidsusukigsxr Non-Generation Specific Questions 2 06-26-2007 03:17 PM
Mysterious Coolant Leak Yoterman MKIII Supra 3 12-18-2006 03:30 PM
gas tank leak burton51m MKIII Supra 14 11-24-2006 06:16 PM
