#1 |
I've just bought an imported twin turbo and I'm having a few problems with getting the heating system working at a higher temperature. There's an induction kit on it and I've changed the anti-freeze and fitted a higher temperature themostat. It was working fine after that for about 100 miles and then it started blowing cold air again. Has anyone got any ideas, or can offer any help about what else I should do/try next?? Thanks!
#2 |
hi
has it used water in 100mls . also when heater goes cold do the pipes to it go cold or any others ? |
#3 |
yea the pipes into the matrix are hot but the pipe coming out is cold but not using coolant
#4 |
7M POWAH! ;)
have you got air in the system? try burping it... start car, take to a steep hill, turn off, have radiator at highest point, take radiator cap off (make sure it's not hot etc), turn it back on, turn heater on full blat on hot, start topping up the radiator till it stops bringing bubbles up, cap her off and see how the heater is then
also the heater unit... theres something you can remove, like a little leg, i think it's clipped into the side, they go faulty occasionally so unclip it and see if the heater works then... sorry that last one may be a bit of fun to figure out lol.. best i could explain at the mo.. maybe someone else can explain that one better ![]()
Please use the forum to ask your questions as they will get replied to much faster than pming me ![]() Pics of my build. "Good girls are just bad girls that don't get caught" ![]() Do a diagnostic first! |
#5 |
Thread Tools | |
Display Modes | |
HELP PLEASE | Nick0887 | Non-Generation Specific Questions | 4 | 02-28-2009 07:26 AM |
Dream Offer | Karma_Supra | MKIV Supra | 22 | 10-17-2007 03:04 PM |
Sequential Turbo Question | suprapoweredsoarer | MKIV Supra | 1 | 06-06-2006 12:13 AM |
