Old 07-14-2009, 08:31 AM   #1
quiky
quiky's Avatar
quiky is on a distinguished road
Default supra overheating
my supra is overheating.. i drive it for half a km and she's up near the red on the gauge..initially i thought, thermostat, so i went and changed that, changed my coolant and gave it another go but still over heats quickly... im now thinking my waterpumps buggered. dont really have much of an idea about these things so any help would be greatly appriciated...
cheers
quiky is offline   Reply With Quote
Old 07-14-2009, 06:18 PM   #2
Bill UK
AEM EMS
Bill UK's Avatar
With so many BHG & high mileage on these Supras it not uncommon for the impellor to disintegrate, when the combustion gases mix with the coolant it turns very acidic and starts etching away at thin metal parts. Worth checking the water pump as you said. Cygnusx1
Old 07-15-2009, 12:45 AM   #3
quiky
quiky's Avatar
cheers for verifying what the issue could be, now i gotta find one haha...
Old 08-25-2009, 08:12 PM   #4
Toyota Fan
Toyota Fan is on a distinguished road
Default some quick fixs
Could be water pump check for blow head gasket by checking for merky white colored oil. check the radiator make sure its not cloged check the therm and fuel lines/filter for clog. I noticed a massive cool down with a K&N system lowered the overall heat by a ton. if none of that stuff works its prob your head gasket go have it compression tested at a shop.
Toyota Fan is offline   Reply With Quote
Old 09-09-2009, 11:16 PM   #5
82Supra
82Supra's Avatar
82Supra is on a distinguished road
Default ovrheatn
Rad...fan clutch...both, all of the above
I tried to skirt around the same issue myself, cost me a head gasket, rebuilt engine +.
I ended up with a good engine, 2 electric fans, reconfigured vacuum lines, plus an education!
Finally, just when I got it painted and brakes done... I pulled out of the garage and a guy slammed into me, totalling the car!
Ended up learning lots about these cars, lessons learned and paid!
Bought what I thought to be a parts car (sight unseen), it turned out to be a minty '82, my daily driver, and lotsa spare parts to boot!
Every dark cloud has a silver lining.
82Supra is offline   Reply With Quote
supra newb overheating vdesign MKIII Supra 13 06-27-2008 05:09 PM
82 Supra overheating suprahusker MKII Supra 2 10-17-2007 01:59 AM
'92 Supra 7MGTE overheating - need help pls. liona MKIII Supra 7 05-19-2006 04:06 PM
overheating problem on 1990 supra turbo suprasux MKIII Supra 16 06-13-2005 10:39 PM
