Stopped at a gas station
went in to get a drink, came out and car wouldn't start...at all
What you can do is shoot some starter fluid in the intake and see what it does from there. If it starts and then stops it might be a fuel problem, if you can check compression and spark if it is at your house, or another location than the gas station. Also listen at the gas tank to hear a whine to see if the fuel pump is working.
found out is was the starter, all replaced. :werd:
