Old 04-15-2009, 07:56 AM   #1
alexdeschutter
alexdeschutter is on a distinguished road
Default 88 Supra - Problem Holding Idle
I went to look at an 1988 supra(automatic) today.
No turbo, and was completely stock as far as i could tell.
The price is fairly low, it runs and starts but i didnt get to drive it.
In the driveway where I started it, i shifted from Park to Reverse to Drive and back a couple of times.
It would run alright but i had to give keep my foot on the pedal otherwise it would slowly begin to stall as the RPMs dropped.
I would like to purchase this vehicle and will be going back with a mechanic(ally inclined friend) for further inspection (check for BHGS and possibly do a compression test).
Does it fall out of idle because of the MAF?
THX for reading and any wisdom you can impart!
alexdeschutter is offline   Reply With Quote
Old 04-17-2009, 12:30 PM   #2
Makz
Makz is on a distinguished road
I think, first of all, you shold run self-diagnostic system, by connecting Te1 and E1 pins in Diagnostic box.
It may be MAF, ISCV, water temp sensor, holes in intake pipes and so on...
Makz is offline   Reply With Quote
88 Supra - Problem Holding Idle alexdeschutter MKIII Supra 9 04-17-2009 10:21 PM
Idle problem again. redmaro MKIII Supra 17 02-10-2007 07:42 AM
Idle problem 1988 Supra non turbo jimwww Non-Generation Specific Questions 3 01-24-2006 03:50 PM
HELP!!!! '87 Supra idle problem Morpho MKIII Supra 0 10-03-2005 02:40 PM
