Old 04-27-2009, 11:45 PM   #1
gcride
gcride is on a distinguished road
Default Low Compression
I just talked to my mechanic and he told me that the number 3 cylinder on my 7MGE has low compression. The head gasket was just replaced with an aftermarket metalic one, the head was milled and toqued on to about 70-75lbs. The car is also burning a quart of oil every 500 miles or so. He says the problem is related to the piston ring and I tend to agree with him but I don't want to replace the engine (which is what he is recommending). Any suggestions?
gcride is offline   Reply With Quote
Old 04-29-2009, 11:30 AM   #2
Makz
Makz is on a distinguished road
Don't worry yet. It's not necessary to replace engine. Probably, change of piston rings will help. If the cylinder is bad, you'll need to bore engine block and replace pistons+rings on o/s 0,5mm
ex '87 MA70 7M-GTE, A/T, targa, rhd
ex '87 GA70 1G-GTE, M/T, targa,rhd
now '90 JZA70, 1JZ-GTE(swap), M/T, targa, lhd
18 inch PIAA Rozza wheels, HKS blow-off, Apexi turbotimer, XTD stage 3 racing clutch, AEM air filter, JZA80 fuel pump, 4-piston Skyline GT-R front brakes, Blitz boost-controller, high performance exhoust system
Makz is offline   Reply With Quote
Old 04-29-2009, 12:06 PM   #3
laughter
laughter is on a distinguished road
Default The General Questions
Hi,
Well every question behind its a answer is also available just need is to search it well and give answer of it.
dataentrypakservices
laughter is offline   Reply With Quote
Compression check when cold gottadiesel MKIII Supra 3 02-26-2009 07:24 AM
Compression and Block Tests mrnickleye Supra FAQ 0 01-29-2007 03:49 AM
Just did compression test...Help with oil pressure! 2JZEFINI-17 MKIII Supra 1 11-06-2006 12:06 AM
looking at a 90 turbo with compression problems jtitzer56 MKIII Supra 1 09-23-2006 05:27 PM
Compression Question Intenseneal MKIII Supra 5 08-15-2005 10:27 AM
