Old 07-29-2005, 12:33 PM   #1
kazam
kazam is on a distinguished road
Anyone know why there are 3 alignment pin holes in the cam(s) and gear(s) ?
Out of the factory the pin is in the center hole. Moving it clockwise or anticlockwise would advance or retard the valve timing. You might need to advance the timing if you milled the head or block. But why would you ever need to retard it ?
kazam is offline   Reply With Quote
Old 07-29-2005, 12:45 PM   #2
and you certainly don't want to adjust timing via the cam gear
you wouldn't want to advance it either... most people when doing mods to their car etc usually retard the timing or get aftermarket cam gears... useful.. for as you say.. the head being milled way out of spec
hth
Old 07-29-2005, 04:28 PM   #3
kazam
There`s not much adjustment in the pin location: + or - 1.5 degree. A tooth,I believe, is 7.5.
Old 07-30-2005, 10:04 AM   #4
if you must adjust your timing do it properly... use the cps or dizzy... and only adjust it if you know for definite what you must change it to
if you change the cam gear onto a different pin you will knock out your timing terribly.. it will be in limp mode.. it won't rev out past 2500rpm (or at least on the gte... what with electronic ignition and all)
i believe they're 1deg each pin? not sure.. haven't measured... have no need to as i have a cps
Old 07-30-2005, 03:15 PM   #5
kazam
That kinda brings me back to the original question. Why are the holes there in the first place ?
Some mechanical engineer`s twisted sense of humor ?
Old 08-02-2005, 04:35 AM   #6
ummm probly the same engineer that torqued our heads down?? h34r:
Old 08-02-2005, 07:16 AM   #7
Poodles
hahahaha, how true, when toyota's are usually so overbuilt it's not even funny...
advanced timing? sd88supra MKIII Supra 7 04-27-2008 03:44 PM
Photos of my timing belt Nato99 MKIII Supra 7 08-27-2007 09:33 PM
Can't adjust timing... Lunch2000 MKIII Supra 7 11-26-2006 04:09 AM
timing issues stuck1 MKIII Supra 0 03-27-2006 02:16 PM
setting timing on a GTE djalkyd MKIII Supra 0 03-19-2006 04:39 AM
