#1 |
After the rebuild there were some issues so i started going down the list of vacuum hoses. Along the way i found something sparking under the fusebox.
Turns out the previous owner had connected some thick wires with a bolt and shoved them out of the way under the fusebox. Anyone have an idea where they are supposed to go ? ![]() Then secondly i have some issues with the vacuum hoses for the fpr. When i look at the schematic i see the VSV having just two hoses connected. However my vsv has 3 hose tubes sticking out. At the bottom of the vsv there is one in location B that goes downwards, should i hook that up to something? Then the A line should go to location C tube, then D tube connects to E line. I can't figure out where the E line ends after going in the metal tube. ![]() Last edited by Gunnar; 06-11-2009 at 07:49 PM. |
Thread Tools | |
Display Modes | |
MK3 supra Hose Techniques silicon hoses | Micahwc | Shops & Part Reviews | 8 | 12-09-2012 09:03 PM |
Vacuum Hoses and Diagrams | kewlcoconut | MKIII FAQ | 11 | 08-13-2007 01:41 AM |
