Old 07-20-2009, 12:20 AM   #1
91turbo
91turbo is on a distinguished road
Default oil line troubles
i am in the process of installing a new head gasket on my 7mgte, and im hitting a snag with tightening the oil feed line from the turbo to the block. i just cannot get the screw to start threading, not stripped or anything. i just cannot keep the back crush washer on and get the screw to set.
91turbo is offline   Reply With Quote
Old 07-21-2009, 09:34 PM   #2
Bill UK
AEM EMS
Bill UK's Avatar
You really could do with two pairs of hands, one jiggling the turbo around a little bit and one locating the banjo bolt. The problem is the pipe is so ridged which makes it awkward to line up with the hole in the block. I tried a small amount of super glue on the washer but had a good result with a very thin sticky sealant to hold the washer in place. Not sure if you can get this in the US. Link It’s also ideal for leaking cam covers. Be careful not to squeeze the tube too hard, its has the consistency of maple syrup. Resistant to water and oil, but no good for fuel lines.
Old 07-26-2009, 09:18 PM   #3
Jimmy224
Jimmy224 is on a distinguished road
Nice Information sharing with us
Thanks
rakhi to india, send rakhi to india
Jimmy224 is offline   Reply With Quote
Where is this vacuum line saposed to connect to? mkiiisupra MKIII Supra 15 07-15-2010 05:15 AM
Changing the Power steering pressure line w/pics! Mahonri MKIII Supra 4 06-01-2009 11:37 AM
Vacuum line routing to HKS SSQV? mkiiisupra MKIII Supra 8 02-06-2008 05:29 AM
Blown line going to EGR Morty MKIII Supra 11 01-13-2008 12:42 PM
Fuel line problem Damian MKIII Supra 1 07-23-2005 10:22 PM
