So i was driving on the highway an my friend told me to drop it from 5th to 3rd. so i did and the engine reved up really fast and i put it back in 5th and it started coasting. my friends say it the clutch because after putting it in 1st gear it wouldnt go anywhere, but after coming home my step-dad ut it in 1st then started the car and drove fine, but it wouldnt go to any other ger besides reverse if you put it their before starting the car. so my step-dad said it wasn't the clutch, possibly the master/slave cyinder, so i repaced those and still the clutch wont go into gear.
Anyone know what the problem might be?? if you live in the Puyallup area i would greatly appreciate it if you came and looked at it. also when pushing on the clutch pedal its not stiff, it comes back up. |
it wont go into gear when the car is on, but when it's off it can only go into 1st and reverse.once it's in the gears then i turn it on it will drive fine but cant switch any other gear.
not exactly certain on this but a buddy of mine had a problem similar to this at the track a few months back on his s14. It was his clutch line. it had expanded and wasnt creating enough presure to fully disenguage the clutch i belive. thats why most of the guys i roll with have either metal braided clutch lines or we have the line reinforced the cheap way (zip ties). Its just a thought but i'm not all that good with tranny and clutchs so. You could try and bleed the lines and it may help enough for you to get it to a shop and have it looked at.
throw out bearing
Replace your bearings
Clutch kit for a 1993 JDM Toyota Supra | SpRuCe | Non-Generation Specific Questions | 0 | 04-13-2009 10:20 PM |
HElp with sports clutch!! | whitequasimodo | MKIII Supra | 3 | 05-07-2008 11:06 PM |
