Old 06-16-2008, 10:04 PM   #1
yotatime911
yotatime911 is on a distinguished road
Exclamation 1986.5 supra turbo engine cutting out
my car is cutting out at about 3000rpm under a load but not in neutral. I replaced camsensor,plugs,wires,coils so its got good spark bt that didnt help. So i did a compression test and the cyclinders all showed good compression at 140psi +or- 5psi. i also know that the fuel pressure regulator is working properly 2 so i am pissed what else should check.
yotatime911 is offline   Reply With Quote
Old 07-02-2008, 05:04 AM   #2
racinrookie88
racinrookie88 is on a distinguished road
Default same problem.. any help yet?
im having the same problem but at around 5000 rpms and when the car has been runnin for a while.. did you find anyone who knew what was wrong?
lmk
Rook
racinrookie88 is offline   Reply With Quote
Old 08-20-2009, 11:38 PM   #3
lostboy
lostboy is on a distinguished road
Did you find out what is wrong
lostboy is offline   Reply With Quote
what do you think of this setup? Jareduhhhh MKIV Supra 4 02-19-2009 10:38 AM
1990 supra turbo engine issues help jespat Non-Generation Specific Questions 4 01-24-2008 02:37 AM
turbo rsx type-s vs. 91 supra turbo SupraMan1784 Road Racing & Autocross 8 12-15-2005 12:59 AM
