Old 08-09-2005, 02:09 AM   #1
John
Guest
Posts: n/a
Hi..my 1988 Toyo Supra clutch is slipping. Does a hydraulic clutch have an adjustment or do I need to replace?
Thanks John
Old 08-09-2005, 02:42 AM   #2
SupraMan1784
SP58GT
i would recommend replacing the clutch, i dont think it has an adjustment but if it does...i still recommend replacing the clutch
Now: Saving for an MKIV
Broken Rides:
Old 08-09-2005, 03:56 PM   #3
monkihead
SP58GT
monkihead's Avatar
wow, mine went from runing to exploding. it never "started slipping.." i could only wish.
monique- better off dead
Old 08-10-2005, 03:41 AM   #4
Poodles
Poodles is on a distinguished road
aye, mine just went out and took the hydraulic system with it, $900 to repair, and I just bought the thing. Guy said it had a new clutch, he lied, so I'm ticked...
Clutch system is very simple, being a clutch cover and a clutch plate with the flywheel. The clutch is sandwiched between the 2 and put under pressure through the clutch cover spring. The hydraulic system only releases the spring. If the spring, or the actualy clutch are warn out, you'll slip. Also, if you get mud, water, grease, oil, ect up into that area, you can also have a problem.
Poodles is offline   Reply With Quote
1988 Toyota Supra Turbo runs very rich need help PhillyKorean Non-Generation Specific Questions 0 10-25-2008 03:28 PM
