Old 09-17-2009, 07:56 PM   #1
pinoy_707
pinoy_707 is on a distinguished road
Default help, i thing the timing is off.
i've been working with my brother on his 1990 supra. we changed seals, plugs, plug wires, head gasket, and so on. we finally got it buttoned up and went to start it, but its running really rough. we were told that its most likely the timing, but we can't get it to smooth out, and it won't idle. any ideas?
pinoy_707 is offline   Reply With Quote
Old 09-17-2009, 11:36 PM   #2
mirage83
Is it a turbo or N/A? If it's a turbo, check the CPS since if it's off even a little bit it will cause the engine to run like crap if it runs at all.
Timing belt questions..... Legionnaire MKIII Supra 0 09-17-2009 09:40 AM
timing problem with knock robertsws MKIII Supra 1 09-04-2009 03:40 PM
Timing question Kevin MKIII Supra 3 07-10-2009 07:52 PM
1991 n/a timing problems jerrods91supra Non-Generation Specific Questions 0 07-06-2008 09:44 PM
Can't adjust timing... Lunch2000 MKIII Supra 7 11-26-2006 04:09 AM
