Old 08-16-2005, 06:02 PM   #1
Makavelli
Makavelli is on a distinguished road
Hey guys/gals, have any of you bought a performance chip for your Supra? I saw one at horsepowerfreaks.com for around a hundred bucks and was wondering if it would actually do anything noticeable.
Thanks.
<span style='font-size:14pt;line-height:100%'>Stock...for now</span>
Makavelli is offline   Reply With Quote
Old 08-16-2005, 07:02 PM   #2
SupraMan1784
SP58GT
i had my ecu reflashed, but a performance chip just changes the maps for the car...into...performance mode, they should do some noticeable differences as long as you at least have bpu, otherwise they dont do much but add minimal power
Now: Saving for an MKIV
Broken Rides:
Old 08-17-2005, 03:59 AM   #3
Poodles
Poodles is on a distinguished road
I wouldn't do it, because everytime you change something, you have to get a new one. If you get a piggyback ECU, you can alter the tune as you improve the car. It cost more, but in the long run...
Poodles is offline   Reply With Quote
Old 08-17-2005, 05:49 AM   #4
SupraMan1784
SP58GT
yea thats true...but since i have a reflashed ecu i dont have to work to hard in tuning the car since the map is already setup for performance...if you get a performance chip and a piggyback...it will make tuning a little easier, but then again ur spending a little more
Broken Rides:
Old 08-17-2005, 09:07 PM   #5
Makavelli
Thanx for the feeback, but I'm not thinkin long term with this engine. I've decided to swap it out once I move to Texas (bout a year or so).
Old 08-17-2005, 10:18 PM   #6
SupraMan1784
SP58GT
then its not worth it....dont go for a performance chip...unless ur swapping the same motor back into the car...if its a different motor its not worth it
Broken Rides:
performance chips for 94 n/a theboy641 MKIV Supra 3 11-30-2008 01:18 AM
Edo Performance Party and Car show (SoCal) promark MKIV Supra 0 05-27-2008 09:56 PM
1990 Supra Performance mods? MKIIISupra90 MKIII Supra 1 02-22-2008 10:41 PM
Performance chips??? 88_supra MKIII Supra 4 09-20-2007 02:19 PM
Gtech Performance meter landspeedxxx MKIII Supra 4 04-24-2006 05:45 PM
