Old 01-23-2010, 10:22 PM   #1
SR5corolla
SR5corolla is on a distinguished road
Exclamation 82 corolla 1jz?
Hi i want to drop a 1jz-gte motor into my 82 corolla. Was wondering if it would fit and if anyone knew sum1 with a similar setup.
SR5corolla is offline   Reply With Quote
Old 01-26-2010, 07:13 PM   #2
I don't think there is anywhere near enough room. Looking a pics the stock 4cyl is pretty snug. If you moved the radiator forward of the support member you may be able to shoe-horn the engine in, but I don't know where you're going to fit a decent sized intercooler... I suppose you could run a hot air setup, but I don't recommend it.
I would look into swapping in a built 3S-GTE.
BTW - the 1JZ was one of the engines used in the MKIII, not the MKIV... MKIV only had 2JZ.
EDIT: I'm going to move this to 'General Discussions'.
